  #103 (permalink)
Old 06-05-2012, 08:26 AM
DanEC's Avatar
DanEC DanEC is offline
Originally Posted by 428street View Post
No idea Dan...I have not been on CC for a while or here or there at best BUT you have my contact info and can email me anytime. I notice the weather striping on the trunk. It's ERA stock which is 100% fine. The original car came with a rectangle weather stripping which I bought from a guy in Duranga, CO that restores AC Aces. Relatively inexpensive and there is a specific pattern it was installed. If interested I can give you more details. Believe it or not the WS did not go around the entire truck not did it for the hood. Also, two pin holes for drainage in the front hood corners. I can go on and on!
Lastly and this is something you can change now. The original cars did not have carpet behind the seats. From wheel well corner to wheel well corner it was vinyl. I just bought the vinyl from ERA to do this upgrade.
Again, all little details but it's what floats my boat.
I looked around for weatherstripping and ordered a bunch from various places but except for some rectangular for the hood I lucked into from McMasters, I didn't have any luck finding a suitable one for the doors and trunk that was skinned on all 4 sides. I needed a thinner weatherstripping on the hood than for the doors and trunk as there isn't much room there and 3/8 thick WS was going to bind the hood up and cause it to sit high. I went ahead with the ERA WS on the doors and trunk. I may change later. But, I have lots of different rolls of various weatherstrippinng laying around in the meantime if I ever find a need for it.
You may have started something with ERA as they did send me vinyl for behind the seats. It took me a while to figure out where the roll of vinyl went but I finally did.
I have drilled the drain holes in the lower corners of the hood and plan on running the hood weatherstripping as you describe (even drilled a small drain hole in the bottom of both doors in case water ever gets in there).
I'm not going to be up to your standard on originality but some of those things I can address as time goes by.
Thanks Frank
