Thread: My MSD failure
Old 06-06-2012, 07:18 AM
scottj scottj is offline
Cobra Make, Engine: Everett-Morrison, 434 cid
Originally Posted by decooney View Post
Well, if you are going to take it that far, might as well add a 2nd distributor and extra coil while you are at it.
That's not that far-fetched... I always ran dual ignitions; one off a crank trigger and the second off the distributor. The crank trigger is for max power while the distributor is retarded 5 degrees and is used for traction control and starting/warm-up with locked advance.
