Old 06-07-2012, 08:46 AM
Tramsey Tramsey is offline
Cobra Make, Engine: CCX 3028
Default Rear Suspension Failure - Rear Trailing Arms
Does the CC kit not use a trailing arm back to the lower wishbone? I have a broken wishbone and it looks like there were no trailing arms/radius arms installed. Seems like there needs to be another link to keep the trailing arm from rotating about the inner fulcrum mounting point, which mine did and failed in the weld area of the tubular section where it mounts to the yoke. I scanned the manual but did not see anything addressing a rear trailing arm.
Thanks for any info.
