Yes it can,pull the flywheel cover,oilpan,rear main cap,rotate top half of seal out.If old seal is rope replace with neoprene unit from felpro. To reinstall apply permatex#3D to the back of the seal and rotate it back in leaving 1/8"of seal sticking out and making sure the seal is installed in the right direction. Then replace seal half in main cap leaving 1/8"of one end sticking out oppisite of the half in the block. Then apply sealer to the face of the cap only from the seal to the rear of the block then reinstall cap then torque cap bolts 95-105ft#
