Old 06-09-2012, 12:00 PM
DanEC's Avatar
DanEC DanEC is offline
Default Figures from dialing in bellhousing runout
I think these figures are going to be OK but see what you think? I'm running a Toploader, Quicktime and bronze pilot bushing. This was the second run. After the first run I loosened the bellhousing and tapped it in the direction it was closest to centerline and then re-torqued the bolts again and re-measured. It appears this shifted it about a thousand.
Top .0128
Left .0155
Bottom .014
Right .0115
The fourth diget was just an interpretation when the needle fell between marks. Six thousands was what I remember from long ago as barely acceptable and I'm well within that.
Dan
