  #114 (permalink)
Old 06-11-2012, 12:05 PM
strictlypersonl strictlypersonl is offline
I still need to check it out with a level and may have to move it around a little on the mounts before tightening them down. The transmission mount has a some adjustment up and down and I guess I'll have to do a little checking of u-joint angles to make sure I end up with a couple degrees deflection to ensure the needle bearings rotate.
Just put the transmission output centerline at 3.5" (+/- .25") above the top plane of the X-member. If you have the Jag-based suspension, the differential angle varies as the suspension goes up and down. Matching angles with the suspension unloaded will not work.
We've used that height spec for 30 years, and never had a problem with the drive-shaft.
