Dan, if you're asking about the difference between the screw-in type plugs and the ones in your block, the ones in your block are just the stock type. If they are all there I wouldn't worry about it. You said 15# at idle, what idle rpm? When the RPMs jumped did the OP jump as well? If so, what did it jump to?
