Old 06-18-2012, 08:45 PM
WardL's Avatar
WardL WardL is offline
Cobra Make, Engine: SPF #2608, Roush 427SR T-W
Just so you don't do a lot of work before checking, you ight check to see your fuel doesn't have too much water. If the fuel is cloudy, it is bad. Ethanol in the fuel (E10)will soak up much more water than fuel with no ethanol (E0) and run fine. But everything has a limit and when too much water gets into your gasoline, the water starts to drop out and settle to the bottom of your gas tank. Cloudy fuel or fuel with little dropplets is the best indicator of a problem. The water is heavier and sits on the bottom of the gasoline.
