Old 06-20-2012, 10:46 AM
olddog olddog is offline
Default Speedometer went nuts - help
Back out of driveway and started forward. Speedometer went nuts, bouncing all over the place. Then it steadied out at 60 MPH (actual speed was about 20 MPH) for 5 or ten seconds. It dropped to zero then came up and stuck at 20 MPH. Next time I stopped, it dropped to about 15 MPH and has stayed stuck there.
The odometer is still working.
Speedometer is a VDO. Transmission has a cable running to speedometer, so I believe it is mechanical.
I was under the dash yesterday fishing some wires. I put 20 miles on it with everything working perfectly since then.
Any chance I bumped something loose or does it pretty much have to be a bad gauge?
