Old 06-22-2012, 11:12 PM
lippy lippy is offline
Originally Posted by ratsnst1 View Post
I have the dynalite 4 piston on the 12.19 roters, then switched to the 6 piston, it was a big difference, and used the 7/8 front master cylinder, with a tilton balence bar works very well. The 6 piston will bolt up to your 12.19 roters.Just make sure you do the embedding process on your pads.
Is that the master cylinder ERA provides, or a different one? Also, did you have them mod the spindle and just buy and install the 6-piston kit yourself?
Thanks for the help!
