Old 06-23-2012, 11:31 PM
Chris L Chris L is offline
Cobra Make, Engine: Python
Default DBA 2 piece rotors/Calipers
Can anyone advise......
Im looking for a front set of 330mm slotted front rotors in a 2 piece configuration if possible. I like the DBA 5000 series. The 343mm are just too tight for my application (Thanks Aussie Mike for the lend !!).
Im running a Holden VT/VZ offset and stud pattern so anywhere around a 50mm or 2" hat will do depending on rotor thickness.
If anyone has something they are looking to shift that would suit, let me know. Will consider 28 and 32mm thick applications. Interested in calipers also, 4 or 6 piston. Im running 17" rims so cant get to carried away.
If the 2 piece thing doesnt pan out, I will go with the DBA 4000 T3 at 330mm & 32 rotors. The VT/VZ offsets are fine and the R8 ,Clubsport units go straight on. Any suppliers people wish to recommend would also be appreciated.
Thanks for the help.
Chris L
