Old 06-24-2012, 11:39 AM
FWB's Avatar
FWB FWB is offline
Originally Posted by lippy View Post
Yes, (1) is true, but wouldn't you get better modulation with 4 pistons, versus one? There is another option as well (Wilwood High Performance Disc Brakes - 1975 Chevrolet Camaro - Front Brake Kit No.: 140-10738), which is the 6-piston kit with 7.3 sq-in per pad. For (2), I think the offset is -0.28, not 0.28, so it is about 1/4" in, which should provide more wheel clearance. For (3), I was under the impression that you use a stock spindle, which should accommodate these kits. I must be wrong there. Thanks again.
did you browse these guys?
Heidts Hot Rod & Muscle Car Parts - Brake Kits
Fred B
