Old 06-25-2012, 10:42 AM
Pinguino's Avatar
Pinguino Pinguino is offline
Cobra Make, Engine: CR2 5.0 Police Interceptor
John: Here are some pic of the shocks that are on it now and the Bolt adjustment you mentioned. You cant see it but there is a set of springs in front of these shocks directly above the rear axle. As far as the adjustable bolts, the one on the passenger side is screwed past the shelf about an inch and the drivers side is out of the shelf not quite and inch.
I would like to increase the rear end height an inch. With the new tires it looks like it is high in the front end and low in the rear. I do want to upgrade to the QA1's but its not going to happin for a month or 2 at least. What shocks did you use when you did your rear end upgrade?
