Old 06-27-2012, 07:32 PM
Rick Parker's Avatar
The only way to compare these measurments is to compare tire diameters (wheels make no difference) then compare measurements from ground surface to the bottom of the main frame rails at the front, about mid way through the oil pan and the rear end of side frame rail near where the X bracing is attached. Otherwise there is a variable as to where the frame is butt welded to the Mustang II cross member which will effect body height.
Rick
