Gary
A couple of thoughts......"
What it would take to install power steering.......
What is your bump steer.....
What ia your Ackerman......
As you go to a larger tire and try to go fast with racing tires slicks......you will find that the steering gets very difficult ....
If you can move your rack back so there is a 10* degree difference from the steering arm on the upright......and ball joint of the rack..... the car wiil track around a corner with ease...
And on the rear ....can you rotate the upright a small amount to get the rear bump steer going in the right direction.
Morris
Morris
