Old 06-27-2012, 09:50 PM
482supersnake 482supersnake is offline
There is a lot of intakes out there that are in-between the two. First sell the Weiand as you will only loose power with it. A Blue Thunder single four is a step up from a Performer RPM and kind of a cross between a factory PI intake and Cobra Jet intake. You also have either a factory tunnel wedge or a Dove copy. I think the best bet though would be an Offy Port-O-Sonic as you would still get the high rpm of a single plane but you wouldn't loose your hood clearence and it also has smaller runners so you wouldn't loose much low end tourqe.
