Thats the height without the body, interior, radiator etc and the rear is on stands. Front suspension is sitting on the max height stops. Sump clearance is 115mm as it sits, which means at ride height it would be around 80mm.
The chassis in the RCM sits quite low and includes cutouts for the exhaust, i really need the sump close to level with the rails if not slightly higher.
