Thread: Rich Running
Old 02-25-2002, 09:39 PM
JEFFSWHEELS JEFFSWHEELS is offline
Steve,
Some of the simptoms you describe could be hinting at an ignition timing problem. Make sure that your vacume and mechanical timing are combining with your static (10') for a maximum of 40 at about 3k rpm. The mechanical advance should have a mechanical stop ring to limit the total advance. The vacume advance needs to be curbed also. Aftermarket vacume advances are adjustable.
Good Luck...JJ
