  #26 (permalink)
Old 06-29-2012, 06:07 PM
Silverstreak02 Silverstreak02 is offline
Cobra Make, Engine: Factory Five, 302
Originally Posted by HighPlainsDrifter View Post
Hi,
1st- Do you have a resistor in the positive lead to the distributor, should be mallory 700. If you do not have the resistor you will burn out your coil.
Replace coil and add the resistor in the power line.
good luck,
Perry.
Perry
The wiring directions for the Maxfire said there should not be any ballast resistors or loom resistance wire in the red power wire going to the distributor. It also said to make sure the red wire supplies 12vdc in the start and run position. I guess the Maxfire is different than some of the others. I don't have a resistor and have confirmed the 12vdc.
Jeff
