Old 06-30-2012, 07:19 PM
blykins blykins is offline
Originally Posted by MOTORHEAD View Post
Finally getting around to final assy of my Shelby alum block, 428 cranked engine that I bought a fluid damper for, then I got to wondering if the stock damper can be replaced with the fluid one without re-balancing the whole thing ? ( rotating assy has been balanced, and is installed) ALSo, the fluid damper is a C.a.T. (Cal. Auto. Transpeed HBF-390 ) Has anyone had any experience with this brand ?
Also I'm wondering the pros and cons of running without the windage tray in the Aviad road race oil pan.
All info appreciated.
Ted
I would change the balancer, but I would not use a fluid style balancer. I prefer quality balancers like Romac, ATI, TCI, etc.
You can swap balancers without worrying about upsetting the overall balance. All FE's have 0 balance harmonic balancers....it's just the flywheel/flexplate that were weighted.
As for the windage tray....
Pros...you may gain a few ponies....maybe not. It may help windage, and then again, it may not.
Cons...the price of the windage tray, an extra gasket to worry about.
Lykins Motorsports, LLC
www.lykinsmotorsports.com
www.customfordcams.com
brent@lykinsmotorsports.com
