Old 07-04-2012, 02:29 PM
patrickt patrickt is offline
It is safer to just rent an engine lift from the rental place. Put a bolt through the back of the head of the passenger side, front of the head of the driver side, then run a good piece of chain from one bolt to the other and you can safely lift the engine up to give you room to work. Jacks can slip, especially when you or your fingers are in a bad spot.
