Lou,
If you are saying that you want to check the alignment because it pulls to the right under braking, your alignment may not be the problem. If this is a relatively new problem, I'd look at the left front brake to see if it is working as well as the right front. If this is a long standing problem, it might be a weak front spring or worn suspension part on the front end.
Tommy
Previously owned EM Cobra
