Originally Posted by TimeForACobra
Ahhhh..... Great catch. I am not sure if it is on the other side. If it is only on one side, I assume it is a shim and I should leave the plate/shim there with the solid mount?
Only if the solid mounts are the same height as the rubber mounts you are replacing. Check that as well.
