Old 07-09-2012, 06:23 AM
AC-460's Avatar
AC-460 AC-460 is offline
Cobra Make, Engine: BBF 545 Stroker Alloy Heads Roller Cam Aluminium Flywheel Twin plate Clutch TKO600 9inch Independent Rear 335x17 Rear 315x17 Front 1140kg
Default Quietening Sidepipes
Just rebuilding my sidepipes...would like to quieten them down a bit... at present they are 2 1/2 perforated tube inside glass packed 4 inch stainless with 2 inch primary tubes...does anyone know where I can buy FLUTED 2 1/2 tube will this make a difference....
I have also seen spiral flite inside the pipe does this quieten??
Just like to be able to quieten the big block a bit
