I have a Holley 3310-4 that has been leaking a little
oil at the back when the car is cooling off. (Tightening things did not stop the leak.) It was coming from the gasked between the carb and the manifold. I bought a parts kit and replaced the gasket. (Just lifted the carb up to change the gasket.) Put the bolts back on and the airfilter and pumped the gas pedal which resulted in gas leaking out at the back on the right side.
Noticed there was one more gasket in the kit -- one with four big holes in it -- I added that, and the gas leak stopped. Then I am being told there should never be two gaskets - one on top of the other (although one sort fits inside the other actually).
I am obviously no mechanic but try to fix things if I can. Can anyone give me some guidance? Thanks.
