Yumski,
Let's see if I am following you correctly.
1) Before the work was done it only over-heated going slow in traffic (city streets) and then when you would be driving faster (freeway speeds) it would cool down and not over-heat.
2) After the work was done it stays cool when going slow in traffic (city streets) and now over-heats when driving faster (freeway speeds).
3) You are still using the same radiator as before.
4) The only change was the water pump and electric fan with a shroud.
Did you have a fan shroud before the work was done?
Maybe a bad water pump? I know it is new but there have been bad ones before.
What size thermostat is in it? 160°-180°-190°?
Is the water pump spinning in the correct direction? There are normal and reverse direction water pumps. (should be ok because it is not over heating at slow speeds)
Is the fan turning in the correct direction? (again, should be ok because it is not over heating at slow speeds)
If it ran cool at higher speeds (freeway driving) before than one of the changes messed that up.
Edit:
In addition, If you are not a member of the Yahoo Sebring Group, you should join. Nothing like getting answers from people with the same exact car as yours.
Terry
"I may be paranoid, but that doesn't mean they are not watching me"
Reason: see edit
