Originally Posted by mickmate
I tried over adjusting the shift linkage to make sure it was going all the way in after trying the alignment pin and readjusting the linkage. I hoped it was a weak detent or a loose shifter arm nut but it was the syncro ring.
very well could be the problem here, but before pulling the trans.,I would check the linkage adjustment.........
David
