Old 02-26-2002, 04:52 PM
Jeff Frigo's Avatar
Jeff Frigo Jeff Frigo is offline
Cobra Make, Engine: ERA 454 S.O.
OhBuoy
Try this:
First, put the trans. in fourth gear. Use the alignment tool to locate the clutch plate. Make sure the clutch pedal is hooked up and set correctly. Install the trans. When you get it close (when you start to feel resistance) have somebody push in the clutch pedal and rotate the tail shaft at the same time.
If this does not work, then you have an alignment problem. I live close to you, if you want help, e-mail me and I will be glad to come over.
Jeff
“If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough horsepower.”
Mark Donahue
