  #44 (permalink)
Old 07-16-2012, 09:13 PM
PDUB PDUB is offline
Thumbs up
Originally Posted by Silversmith View Post
Ohh! so fancy. Nice shinny tool! I built my spinning tool with a 1/2" X 3 3/4" dia. steel plate; 3 equal sections of schedule 40 black iron pipe 1 1/2" depth by approx. 2" long. Placed the 3 equal parts on the 1/2" disk to fit in between each spinner fork, marked the disk & welded the pieces to the disk. Next I welded a 3/4" impact socket to the center of the back side of the disk. Smoothed the sched.40 blades to insure no damage to the spinners & then cut std. 3/8" fuel line 1 1/4" long & split on 1 side. To fit on to each side of the cut pipe/tool blades. It works the Balls!! It also only cost about $10 to 15 bucks & a couple of hours labor. But my spinner tool isn't shinny It's only painted flat black. But it does save the cost of a lead hammer every year or so! & allows for accurate torqueing of the spinners
If you can't document it, it didn't happen! Show us... please, so we can believe.
Paul
Unique Motorcars 289 USRRC
1964 289 5-bolt block
Toploader and 3.31 rear
