Old 07-16-2012, 09:33 PM
AC-460's Avatar
AC-460 AC-460 is offline
Cobra Make, Engine: BBF 545 Stroker Alloy Heads Roller Cam Aluminium Flywheel Twin plate Clutch TKO600 9inch Independent Rear 335x17 Rear 315x17 Front 1140kg
Thanks Rob good to see what your doing...I was going to try an Auger flight (spiral) that has only a 15mm hole up the centre an 62mm on the outside and slide it the full length of the peforated tube...
