Thread: 427 fe
Old 07-18-2012, 10:33 AM
FWB's Avatar
FWB FWB is offline
Originally Posted by cobrabritt83 View Post
has anyone put a 427 Fe engine in ther cobra if so how did you get the measurements to know where to mount the motor mounts on the frame rails.
if the rear is already mounted, you will kinda have to work from the back front.
mock up a block and your trans to be sure you have enough room for a driveshaft....it'll be quite short. have the mounts on the engine
things to consider...
oil pan to ground clearance,
carb and aircleaner to hood clearance, watch out for this one...
pinion angle
Fred B
