Old 07-18-2012, 12:10 PM
Dangerous Doug's Avatar
Dangerous Doug Dangerous Doug is offline
Cobra Make, Engine: ERA 289 FIA #2108
I suggest not messing around with weird fittings and modifications to your existing fuel pump. For about $100 you can purchase a new fuel pump with the correct AN fittings for an SS line. You'll spend close to that on weird fittings to accommodate the mechanical Carter fuel pump in the picture anyway. Run AN fitting SS line up to the carb. I think this would be a more elegant solution to your problem.
DD
Dangerous Doug
"You're kidding, right?"
