Just to clarify, open up the hole in the rotor so the spacer ring fits inside. The hole in the rotor should be slightly larger than the outer diameter of the spacer ring. I ran into the same issue. I spoke to Olthoff when I was doing my job and was advised to open the rotor. The new hubs no longer require the spacer ring... I hope this helps...
