Old 07-20-2012, 11:43 PM
MotorcityCobra MotorcityCobra is offline
Cobra Make, Engine: Classic, 347
Default Windsor with Cleveland 2V heads question
Still learning about the Ford Small Blocks. I have a nice 289 short block, but has way higher compression than I want. Then I started looking at the Cleveland heads and noted that the 2V's have 74cc volume (which would seem to be way low compression with flat top pistons).
I know the heads are not a direct bolt on (coolant mods required, I think), but does it make any sense at all to pursue using these dome pistons (-10.4cc) with the 2V's?
Thanks.
