07-21-2012, 01:47 PM
NH
If you want to do a compression check before we tear it apart let me know. We can also pressure test the cooling system and check that for leaks. If you smell exhaust in the expansion tank or see it bubbling in there with it running and the thermostat open that means compression is leaking into the coolant.
