With transmission in gear, clutch pushed in. and car stopped, rev engine and see if vibration is still there. If it is, it cannot be the clutch, as it is not turning.
There are two different off set balance options for the SBF - 28 & 50. Also some aftermarket builders internally balance the crank. Do you have the correct flywheel and harmonic balancer for your engine? Are you sure?
