Originally Posted by cobred
You should also check what mufflers are inside your sidepipes. When I first built my car I bought the sidepipes from ERA and didnt ask anything about mufflers. The ones they gave me had 2" mufflers inside the pipes. A few months later I bought a used set with 2 1/4" mufflers from ERA then a year later I sent the first set to the exhaust shop ERA uses and had 3" mufflers installed.
Each change made a difference but I made other changes at the same time so its hard to say how much of an increase but what goes in must come out.
Good thought and while your at it, make certain your air filter is not choking off air flow. Air flow into and out of the engine is king.
