  #34 (permalink)
Old 07-25-2012, 10:27 AM
DanEC's Avatar
DanEC DanEC is offline
I wouldn't assume your heads and intake were port matched. If it's a stock rebuild they probably didn't touch them.
You might want to do a compression check and leak down test of your motor before doing too much to it. You should find out if your motor is basically healthy before getting too deep into it. If you have a couple weak cylinders then a lot of these suggestions are going to produce marginal results.
