Corner weights
Steve,
For race alignment specs give Regg a call at BDR. It depends on the tire your running. I'm running a bias ply Goodyear Racing slick that doesn't like a lot of negative camber. Regg has run just about every combination at the track and has always helped me with a place to start.
For ride height get the car as low as possible in the front without tire rub. Then set the back to 3/4 to 1" higher giving it a bit of rack. As for corner weights, the last time I" weighed the car it came in at 2699LBs. RT front 630LBs., LFT front 612LBs., RT rear 736LBs., and LFT rear 720LBs. These are with me in the car.
Good luck,
Mac
