Originally Posted by brandx
This may be a stretch but do you have another set of tires to try?
Yes, I have a matching set I was saving for the race and you are right it is worth a try if I don't find anything when I inspect parts.
Rick,
I should have marked the tires and rims but did not, it could have slipped them or maybe set up a harmonic in those big side walls. It was breaking traction whenever I had the guts to get it all the way down. I am going to look at the pinion bearing and the slip yoke bushing too. I set ride height for handling/ rake and am wondering if I am getting an angle or no angle on the half shaft joints that might cause a problem.
