Thread: Webers on ebay
Old 07-29-2012, 07:26 AM
wideglidejoe wideglidejoe is offline
Cobra Make, Engine: FFR MK III,462 FE/TKO 600, IRS w/3.27
Dallas,
Thanks! I see you have Weber's too. The setup on ebay is a FE intake, and the Weber's are tilted towards the middle, so I'm assuming thats what everyone refers to as the 10 degree tilt.
I have scanned all of the Weber posts, there's a lot of good info there. If I go with Weber's, I'm sure I'll be using all of that info, along with getting some help.
As far as cam, I did see in the posts that cam selection is important with Weber's, so I'll decide on cam after I decide on Weber's or not.
Thanks!
Wideglidejoe
FFR#6143 Mk III: FE 462" w/four 48 IDA Weber's w/TKO 600 .82, IRS w/3.27, 17" Team III's w/245/45's & 315/35's. Gas N's.
Picked it up end of Aug '08
First start May 12, '10
First go kart May 26, '10
Tag & title 5-26-11, driving in gel coat
Painted Nov 2015
'05 Harley Wide Glide (60 hp stock, now 107 hp & 107 ft/lbs at wheel. Mid 11's in the 1/4 mi.)
'55 Bel Air hot rod project (WIP)
