If you insist on an Edel, you want a 1407, 750cfm with electric choke. But Edels are OK only on stock engines. If you have any duration at all on your cam, your Edel won't like it.
I've had several Edels on engines with lots of cam, had to ditch the Edels and go to Holley or a Holley clone.
I'd eliminate all other possibilities before assuming its the carb.
blykins knows his stuff, you'd be wise to listen to him.
Good luck...............
Wideglidejoe
FFR#6143 Mk III: FE 462" w/four 48 IDA Weber's w/TKO 600 .82, IRS w/3.27, 17" Team III's w/245/45's & 315/35's. Gas N's.
Picked it up end of Aug '08
First start May 12, '10
First go kart May 26, '10
Tag & title 5-26-11, driving in gel coat
Painted Nov 2015
'05 Harley Wide Glide (60 hp stock, now 107 hp & 107 ft/lbs at wheel. Mid 11's in the 1/4 mi.)
'55 Bel Air hot rod project (WIP)
