Old 07-29-2012, 01:14 PM
Bobcat Bobcat is offline
Naja289 ... Can you define hot ? 200 degrees or is it a bunch hotter .... does it cool down when you get moving ? Are you running straight water or a glycol/water mixture ?
I use the water wetter and it does work , but isn`t a cure-all if there is a problem in the cooling system ( stuck thermostat , fan not shrouded , bad radiator cap , air in system etc ) . I see 190 to 195 in traffic and stopped .... ambient here ( SC ) is in the 95 to 100 degree range now . Cools down to 180 to 185 above 35 mph . Can`t give you a specific reduction as I`ve never run a car without it .
