Fred, Lou,
Thanks for the manual link. I would like to check that one out to see how it compairs to mine. As far as the windshield, all I have is the WCC part number from the build sheet which is L4-0123. This probably won't do anyone any good cause it's just a random # WCC gave it. I had thought the windshield was common with others and it's good to hear it is as mine is starting to de-laminate around the corners and will have to be replaced at some point.
I accepted your friend request Lou.........thanks.
Ray
If you go in the out door, are you coming or going?
