Old 08-06-2012, 08:58 PM
Jaydee Jaydee is offline
Cobra Make, Engine: CR Cobra 3169
You shouldn't adjust the clutch at the pedal. The mc always has to come back to the stop. You can only adjust it at the slave, until the freeplay is taken up. If you adjust the pedal, the fluid can't flow back into the resevoir, and you will end up pumping the slave until It either pops out, or you push the bearing through the fingers.
JD
