  #87 (permalink)
Old 08-08-2012, 02:58 AM
garyjettrike's Avatar
garyjettrike garyjettrike is offline
Cobra Make, Engine: Chevy LS3 supercharged
Originally Posted by Morris View Post
Gary
Your comment on the rack having to be in line with the lower control arm to have zero bump steer is not correct......
There's a line between the inner upper pivot (upper control arm) and lower pivot (or lower control arm) that you can have the end of the steering rack mounted on....
And as you guy's get up into larger GT-1 type of cars....you will start to under stand how we have been able to get larger cars to handle on race tracks....and the lower control arms are mounted under the chassis so low that you can't get a steering rack down to that level.
Ackerman works better on Sedan type of cars then on formula cars....
Just trying to give you some of the experience that took us many years to acquire.
Morris
Morris, I agree with everything you are saying as long as you are talking about a conventional double A arm system. With the camber compensation system the top A arms are constantly moving in and out to adjust camber and the nearer you are to the top arm the more steering deflection you will get as the arms move.
This web sit explains how camber compensation works.
The Camber Compensation & Anti-Roll (CC&AR) Suspension System
Regards Gary
