Old 02-28-2002, 05:06 PM
Whaler Whaler is offline
Default Bleeding
Page 3 describes bleeding the unit
"Fill master cylinder with DOT 3 Blake fluid not silicone fluid or damage to o-rings will occur. After master is full, bleed bearing the same way as you would for brakes. ie. pump pedal 3 or 4 times hold down on pedal and open bleeder screw on bearing bleeder line. This will release fluid and air trapped in the system. Do this until all the air is out. Pressure bleeding is recommended to evacuate all the air form the system. Once bleeding is complete, bring fluid level back up in master cylinder, but not to top. Leave fluid down 1/2 to 3/4" from the top this allows fluid to return when the bearing self adjusts.
Unlike brakes the fluid level will rise in the master as the clutch wears not lower "
Tim
