Old 08-10-2012, 06:25 AM
jhv48 jhv48 is offline
Make sure your electric choke is fully opening. Let's start simple first. What do the plugs look like? Float level ok? You have already ruled out most of the usual suspects. If you can swap out the carb, it would either rule it in or out of the equation. I like the vacuum leak test too. A tiny piece of dirt in a jet could easily cause this problem.
Jim
