Originally Posted by lovehamr
Weeny, by torque, do you mean what the engine puts out? If so I don't have to guess, at least not with a carb. I dynoed it with a 1050cfm Demon and it twisted the dyno to 497#. Is that a number I'll need?
Steve
Yes, but you may not want to start that high. A larger torque setting will put more fuel at low end and less at high end. To fine tune, you'll spend some time data logging, driving, data logging, driving, etc. However, once done, it'll be great. Example, I have a 331+ stroker with aggressive cam at 350 torque setting. I raised it from 300 and it made a huge difference.
The system will "learn itself" but if you help it, it'll take less time to learn.
