Gday Pete,
I know where the sensor should be as the casting is there for it but it is not drilled out. Im not sure if the tone wheel would still be on the output shaft.
There are some aftermarket options i have found, dakota digital have one that mounts to the side of the driveshaft and then you stick 4 magnets on. This wouldnt work with my ECM as it is 4k, there is another one available that mounts to the diff input yoke. Im thinking this may be my best option as i dont really want to take the gearbox apart and machine out the housing now that it is painted.
Im sure im not the first to come across this. Either i am really missing something or others have had this problem.
Liam
